a/c not workin
Old 07-09-2010 | 08:28 PM
civicvtec95's Avatar
thank u all for ur help , i found the problem the ground wire was loose to the ac compressor relay
Old 07-09-2010 | 08:37 PM
Hmmm...what ground wire are you talking about? Even unplugging the compressor clutch relay would not prevent the condenser fan from running.
Old 07-10-2010 | 03:17 PM
there was a ground wire loose and i tighten it up and it work . it was located on the left side by the air intake on the side of it
Old 07-10-2010 | 03:36 PM
The only grounds, if bad, that would prevent both the fan and compressor clutch from working would be G201 and G401:
And if they were bad, there would be many other electrical problems.
Old 07-10-2010 | 03:39 PM
it was g201
Old 07-10-2010 | 03:42 PM
it was g201
Okay. That makes sense. By convention, the passenger side of the car is referred to as the right side not the left side.
Old 07-10-2010 | 03:44 PM
ok thats what i meant i was talking like i was looking at it from the front .
Old 07-10-2010 | 03:50 PM
Yeah, by convention, right and left on a car are defined relative to facing forward in the driver's seat.
You must have had several other electrical problems that were also fixed by tightening G201, right?
1.6LNVTEC
12-18-2010 09:20 PM
c4rtm4n
05-21-2010 04:25 AM
zilliboy
11-28-2008 05:40 PM
POLYTHING
03-23-2007 11:16 PM
01CivicEX
11-28-2005 06:16 PM
Quick Reply: a/c not workin
