a/c not workin
Old 07-06-2010 | 09:25 PM
civicvtec95's Avatar
Default a/c not workin
my compressor will not come on and my a/c fan will not come to, a.c has right amount of oil and r134a. it is blowing hot air , what could be the problem
Old 07-06-2010 | 09:33 PM
Check the condenser fan fuse in the under-hood fuse box (it's by the battery). If it is blown, neither the compressor or condenser fan will work.
Old 07-06-2010 | 09:58 PM
fuse is not blown , there is a cooling fan relay and a/c compresor relay would tht not make them work
Old 07-06-2010 | 10:03 PM
Yes, that was what I was going to have you check next.
There is also a relay over by the driver side headlight, mounted on the radiator support.
Old 07-06-2010 | 10:06 PM
it is not labeled i think it is the one on the right but not sure
Old 07-06-2010 | 10:11 PM
I'm not so sure either, actually... reason being that mine are actually just hanging there because the mount portion of the relays broke off.
Old 07-07-2010 | 03:50 AM
What model year is it?
Old 07-07-2010 | 05:17 AM
IF you have a 95 Civic:
1) Check 20A hood fuse 35 and 7.5A dash fuse 13
2) Check the A/C thermostat in the evaporator
3) Check the heater control panel
Old 07-07-2010 | 07:14 PM
its a 95 civic vtec 1.6
Old 07-07-2010 | 07:36 PM
Take the glove compartment out and locate the thermal control on top of the evaporator box. It has a 3 wire plug and a gray wire that's permanently attached. Unplug the plug and check the wires:
blue/white should have continuity to ground whenever the fan switch is on any setting other than off, and the A/C button pressed. If not, problem with the control panel.
yellow/black should have battery voltage whenever key is on.
yellow/white jump it to ground (or blue/white) with engine running, compressor should start.
If all these tests pass, thermal control is bad.
Quick Reply: a/c not workin
