A/C not cold half the time
Old 07-05-2011 | 09:49 AM
daisy5's Avatar
Default A/C not cold half the time
I have a 2010 Civic EX with 14,000 and around the end of May the a/c wouldn't get cool. I took it to the dealership and they said nothing was wrong, but when I got back in the car the a/c was cold. It was cool for a couple weeks and I have the problem again. I took it again today and again they said they couldn't find anything wrong. They said they would keep it over the weekend and check it out. Sometimes it gets a cool spurt but most of the time it's just a tad cooler than with the windows down. Does anyone have a clue what might be wrong?
Old 07-05-2011 | 05:14 PM
90 Civic's Avatar
My guess is a blend door not working correctly. Possible leak. Most likely something simple since it is a new car. But will a dealership figure out is the bigger question.
Old 07-05-2011 | 06:25 PM
When it is not cooling, park the car-- leave the engine running and the A/C button pressed-- open the hood and note if the compressor is engaged (plate on the end spinning) and the condenser fans are running.
Old 07-06-2011 | 12:43 PM
mundy5's Avatar
daisy, you need to bring the car in running while the a/c is not cool so that the dealers can see it and try to figure it out. obviously at startup it is cooling properly which is why they don't see a problem. You need to find out when it starts going hotter than it should be and then re-create the same conditions for the dealer or as I said earlier, to bring it in when the a/c is not cold.
Flipz
04-12-2011 10:59 AM
splman75
08-01-2005 11:14 PM
LEVIII
07-19-2005 12:52 AM
unreg
12-10-2004 10:03 PM
Quick Reply: A/C not cold half the time
