A/C compressor
Old 04-16-2008 | 05:05 PM
snipe1905's Avatar
Default A/C compressor
I have a 2001 Civic whose A/C compresoor does not run. However, there's some electronic component on it, and if you jump this thing, the compressor starts right up. So, does anyone know what this is? Is it replaceable? Is it OK yo leave it permanently jumped? Thanks!
Old 04-17-2008 | 05:52 AM
Default RE: A/C compressor
It's the over-temperature switch. If you run low (but not completely out) on refrigerant, the compressor will overheat and that switch will protect it. I think it is glued to the compressor so officially it can't be replaced seperately.
It is OK to just leave it jumpered, you do risk compressor failure trying to keep running while low on refrigerant. If you notice a loss of performance turn off the A/C manually until the charge can be checked.
Old 04-17-2008 | 04:02 PM
snipe1905's Avatar
Thanks very much. Since the switch is non-replaceable, it comes down to replace the compressor now, or possibly in the future. I know what I'll do. I'll be careful - I've already fixed the car so the A/C doesn't stay on all the time when using defrost.
Bill
Old 04-18-2008 | 06:17 AM
AgentofDarkness's Avatar
There is more than one switch that controlls the compressor clutch. There is also a pressure switch that disengages the compressor clutch if thepressure is to low (or high, don't remember at the moment). I would find the pressure switch and jump and see if the compressor turns on. There might be one other switch that controlls the clutch as well. Don't have teh schematic right now so I can't tell for sure.
mahmi
08-04-2005 04:24 PM
AgentofDarkness
06-30-2005 07:02 PM
95import
06-29-2005 02:07 PM
turbo93si
01-17-2005 09:20 AM
rtecson
08-04-2004 03:11 AM
Quick Reply: A/C compressor
