broken lug nuts
Old 04-25-2005, 08:41 AM
toomyboy's Avatar
Default broken lug nuts
Two of my four lugnuts broke off on the front wheel due to my girlfriend thinking it had four wheel drive. What will it take to replce them and what do i need to do. Any ideas please.
Old 04-25-2005, 09:53 AM
polo708's Avatar
Default RE: broken lug nuts
just the lug or the stud itself? Im confused?
Old 04-25-2005, 10:29 AM
toomyboy's Avatar
Sorry its the stud
Old 04-25-2005, 10:47 PM
sacicons's Avatar
you need to take the front knuckle off and take it to a machine shop and have the wheel bearing pressed apart, then have all new studs pressed in. if you only do the 2, then when one of the old ones breaks in a week, youre really gonna be pissed. its a couple bucks extra for each one. and be prepared to buy a new wheel bearing, as its possible for the press to break the bearing.
Old 04-26-2005, 11:15 AM
Don't forget to buy new nuts.......for the studs.
Old 10-12-2006, 08:10 AM
I HAVE 17 INCH RIMS AND TWO LUG NUTS BROKE IN SIDE CANT GET RIM OFF
Old 10-12-2006, 09:05 AM
mill$civic's Avatar
what do you mean broke inside?
Old 10-12-2006, 09:13 AM
drbyers's Avatar
just have the car towed on a flatbed to a shop, if possible.
and NEVAR let your gf drive your car again...
Old 10-12-2006, 07:22 PM
mustangphil302's Avatar
I'm confused here. What are you guys talking about? Machine shop, to replace a stud??? Knock them the f**k out with a hammer and when you put the new ones in put a larger diameter nut over it and use new nut and impact wrench (if you have one, if not sucks to be you, gotta do it with a wrench) to pull the new stud in. Look in "Do it Yourself" forum of this site, I believe there is a thread on how to tdo it at home. Good Luck.
Old 10-13-2006, 01:15 PM
ORIGINAL: toomyboy
[sm=lame.gif]
Quick Reply: broken lug nuts
