Brake lights wont go off
I have a 98 Civic and the brake lights wont go off. It appears the button behind the brake pedal broke because there is blue plastic on the floor. What is the part called that I need to replace?
It's not just that the rubber piece on the pedal arm cracked and fell out? That's what usually causes the brake lights to stay on. Press the button on the switch with your finger and see if the lights go out.
You can go to hondaautomotiveparts dot com and look at a diagram of all the parts with their names.
I did a quick fix by epoxying 2 washers on the pedal arm to depress the switch.
lsufoolsball69
05-11-2009 12:00 AM
Cosworth
12-15-2008 05:35 AM
1994hondacivicbrando
04-24-2008 04:03 PM
Act of God
01-20-2007 04:53 PM
