bogging, code 43
bogging, code 43
ok soo i have 2 other threads with alot of headaches, finally getting somewhere, pulled the code and its code 43, i am getting bogginf in low rpm's, and ONLY under a load what do you think? here are the 2 other threads
https://www.hondacivicforum.com/foru...ad.php?t=78387
https://www.hondacivicforum.com/foru...ad.php?t=78273
im in NEED FOR HELP!!
yea ive been googling it, but is that the correct for the p75? because on some cars its fuel supply and or 02 sensor.... and if im correct the 02 sensor can make things bog right? i noticed today the o2 plug was REALLY oily, so i cleaned the hell out of it with MAFS cleaner, cleaned up well. but still ran like shat
a guy i talked to said the fuel relays go out alot or main relay, he thinks he knows everything about hondas and i dont get why it would run at all if one of those relays were bad.
i just googled OBD1 codes and got that
i didnt really notice much difference before/after i had an 02 sensor back when i did my mini-me (and the 02 sensor threw a cel all the time) so i dont think its that
and i dont think its a main relay either
but i no nothing about fuel relays nor have i ever heard of one
hmm
well what u think Fuel pump? or... ecu out of tune? doubt it because it ran good before. fuel relay, fuel pump? or maybe not fuel 02 ? And if it is the fuel pump , do i jsut buy the pump for this car stock? or does it change because the swap?
ktownjeep
06-20-2007 01:40 PM
Black Magician Hiro
01-15-2005 08:47 PM
