bogging...
ok
so let me add some more info, the iacv is jumpy, always has been dont mind, the car sat for ~3.5 weeks, i inspected the wires where they go into the valve cover and plug in, they look fine no archs, distributor has oil in it, probly the bearing going out, i dont think the sizzys have sensors in them so i dont think thats it, the car has been turned to (what a guy told me by looking at it) obd2 but i think hes wrong and its obd1 (didnt know u can make it obd2) the light threw a code up and after i turned it off it went away, that was twice, there are 2 wires blue and orange coming out of the ECU, is that where i jump to check my codes? i dont know where to check the codes because its been re-wires im assuming, well the origonal jumper is not there and i cant find one
they do they have a cps (camshaft position sensor) dpfi is the only ones who dont have it. and the 96 and up have it on the crank
kdubbla
D15B
* VTEC
* Found in :
o 1991-1995 Honda CRX Del Sol VXi EG1 (Japanese Market)
o 1991-1995 Honda Civic VTi EG4 (Japanese Market)
o 1991-1995 Honda Civic VTi EG8 (Japanese Market)
so its japanese only motor , soooo..... could very well be the dizzy then huh?
* VTEC
* Found in :
yoyo
YOOOO ok new front o2 sensor and my car is runnin good so far, test drove it for 20 minutes, the the 4 wire o2 sensor and its a lambda o2 sensor which means it regulates how much fuel goes into the engine, sooo
conclusion:
code 43
bogging
car is obd1 with a 4 wire o2
this could help others
conclusion:
code 43
bogging
clong0812
05-01-2007 07:03 PM
dragoth
03-14-2007 04:59 PM
Underwhere
07-11-2006 06:29 PM
