Battery has no fluid in!!!!!
My car seemed to not start in the mornings, once I'd driven around all day it seemed o.k, but more often than not in the morning it wouldnt start again! I took the battery off tonight to give it a slow charge over night and had a quick peek at the fluid levels, couldnt see a thing! tilted the battery to see if the fluid would show itself but nothing there! maybe theres a tiny amount in the bottom part where I cant see, the battery did seem to charge up during the day so there has to be a bit in there somewhere eh??
I have'nt got any thing to top it up with and was just wondering if you reckon the battery is worth replacing or just topping up with acid and distilled water????
or could I get away with some boiled water for now? would that even work??
cheers
cheers
RE: Battery has no fluid in!!!!!
Battery is only good for about 3 years old so if it is older then replace it. Most newer car battery do not have a cap to add more distill water and if yours is like that then replace it. Many newer battery has a window on top that shows color so read the label near it to see if there is a color code for what the color stands for.
Replacing the battery would be best; however, if you decide to add fluid, only add distilled water. Adding acid or boiled tap water will destroy the battery if it happens to be good, which seems unlikely.
ORIGINAL: Civic Si 00
what about acid liquid for batteries. Auto zone sells especial acid to refill them
quaterpounder
04-22-2023 05:45 AM
pippo
06-16-2014 12:08 PM
Knobmeister
04-14-2012 05:47 AM
enigma34
05-13-2009 06:41 PM
addiction2bass
07-24-2006 08:57 PM
