Battery Acid all over; strange electrical problem
Old 07-25-2005, 04:03 PM
Default RE: Battery Acid all over; strange electrical problem
All depends how much came out of the battery. Besides, you shouldn't put a new battery back in until you've solved the problem.
Old 01-11-2007, 10:44 PM
i had the same proble, well except i did not let the batt. blow up. anyways i replaced the batt. and walla. problem solved
Old 01-12-2007, 08:39 AM
Stumasters's Avatar
Charging system can be checked at any auto-zone or other good auto stores, and they will remove your old battery and sell you a new one if thats the case, why not check both, since the check on the system is free :-)
Old 01-12-2007, 11:50 AM
riceburner700's Avatar
thread from the dead
Old 01-12-2007, 12:15 PM
This is way over a year old lol
Old 01-12-2007, 01:07 PM
AgentofDarkness's Avatar
Why people bring these threads back i dunno. I would guess that the voltage regulator in the alternator has gone to **** in this case. You wouldn't need autozone, just a voltmeter. Check the charging voltage at the battery (put the leads across the battery terminals while the engine is running). If the voltage is a steady 13.5 volts, it should be ok. If the voltage is jumping around w/o touching the throttle then the voltage regulator has most likely gone bonkers.
Knobmeister
04-14-2012 05:47 AM
gixxer
06-19-2011 02:11 PM
goliath
05-01-2010 08:40 PM
GMstorm
04-20-2010 02:46 PM
drp58
08-02-2005 07:28 AM
Quick Reply: Battery Acid all over; strange electrical problem
