bad wrench
bad wrench
mechanic put on timing belt....2004 1.7 auto...cut first water pump o ring....found after first test drive...car ran perfect...just a leak...put back in shop to correct....somehow an 80 amp fuse blew....could not find anything wrong.....replaced fuse...it did not blow....car starts for approx 5 seconds and then dies....we can not figure it out.
RE: bad wrench
the motor is in time....ran perfect the first time also....the belt was only removed again to correct the cut water pump o-ring.what would cause the 80 amp to blow...and then not blow again when replaced....this car came in over a year ago with the alt out.......we replaced one...and the car ran fine....we done the brakes and some tires....and the belt was just a preventative measure.....really has us stuck...thankyou kent
RE: bad wrench
The alternator wire likely was shorted to blow the 80A fuse. Did you check whether fuse 4 or 20 was also blown? Check the alternator circuit carefully.
By the way, the 80A fuse also protects the ignition circuit, so you should check for blown fuses there as well.
Is the CEL ON?
Is there spark at all four plugs?
Is the fuel pump priming?
Is the CEL ON?
RE: bad wrench
ORIGINAL: RonJ
Is the CEL ON?
Is the CEL ON?
TheInternet
01-20-2008 01:31 PM
cnote
12
04-06-2006 08:41 PM
97civic123
12-01-2005 11:01 AM
