BAD FUSE?
BAD FUSE?
i have a 1998 honda civic EX and my gas gauge does not work...its always stuck on FULL when it should be on EMPTY i was wondering if it could be a bad fuse and if so which one is it....i do not have a car manual....is there anywhere i can go with a diagram showing which one is which or possibly one of yall would know...thanks
RE: BAD FUSE?
There is a fuse but is for use more than the fuel gauge, You either have bad connection, bad sending unit, or a bad gauge. I would make sure every connectiion is secured. Check around the fuel sending unit first. There are three wires for your sending unit - black is ground, yel/blk is for your fuel gauge, and yel/red is your low fuel light.
mcmichael13
01-22-2008 07:51 AM
IMPORTEDCONCEPTZ
12-10-2006 09:46 PM
