Axle problems?
well a axle is easy to see if its loose, just jack the car up and turn the wheel with you under the car... if you see or hear alot of slack in the axle shaft then its bad.
or test the balljoints to see if its the upper or lower balljoint or even the tie rods could even be busted bushings.
theres so many things that could be poping we just need more info of when does it do it and when does it not....
a combo or just a single item.
over bumps
turning
accelerating
stoping
over bumps
turning
accelerating
stoping
Well, it's coming from the front drivers side of the car. I've heard what a bad cv joint sounds like and it sounds very similar to that when accelerating and turning left. Could it be the cv joint?
replace the axle
