Automatic p30 ECU Problem
Old 05-24-2007 | 08:56 AM
nightrider46's Avatar
Default Automatic p30 ECU Problem
on a b16 obd1 ECU,which wires goes from the ecu to the distributor?
also what is the CKP P connected to and what is the CKP M connected to? those are the pinout on OBD1 Connector B pins (b15 and b16).
I want to run a straight wire from the ecu to the distributor but i need to know what are the CKP connects to on the wires of the distributor
Need help her guys, i tried to search now i need knowledge from people
Old 05-25-2007 | 06:58 AM
mxs's Avatar
mxs
Default RE: ECU wires to Distibutor wires??
see if this helps
http://ff-squad.com/technet/wiring.obd1.htm
Old 05-25-2007 | 09:10 AM
thank you that help. my car is running fine now, all i have to do is connect my knock sensor and find a way to get rid of code 19-lock up contorl valve, which i have no clue for this and dont know what it does.
Old 05-25-2007 | 09:16 AM
mxs's Avatar
mxs
code 19 has to do with automatic transmissions...
are you sure you have the right ecu? what is the full code on the side?
Old 05-25-2007 | 09:20 AM
Yea i have the right ecu, i have a auto b16 with an auto p30 ecu. but the redline sucks on a auto b16, my car switches gears @7200rpms, but when i rev it in nuetral it goes to 8300. whats wrong?
nightrider46
05-13-2012 07:52 AM
Captain_Sl0w
08-19-2008 06:41 PM
sebvegas
02-11-2007 03:11 AM
Marty
07-31-2005 01:21 PM
nightrider46
07-17-2005 01:35 AM
Quick Reply: Automatic p30 ECU Problem
