ATF leak
ATF leak
so idk anything about these gay *** transmisions called automatics
but i do know mines leaking
where do the normally leak from and can i fix this on the car?
its loosing quite a bit like 3-4 inch puddles everytime i move it
91 civic dx
91 civic dx
You need to find out where YOUR car is leaking so you know what it needs. Drive up on ramps and clean the bottom of the transmission thoroughly and see where it comes out. You can also put paper under the car (while it is raised so you can look underneath) and then follow the drips back up.
Common leak spots are
Axle seals -- easy fix, same as a manual
Cooler lines (from transmission to radiator)-- usually easy fix.
Input shaft seal (ATF will come out the bottom of the flywheel housing between the transmission and engine) -- transmission must be removed to fix.
When topping up the transmission, NEVER use generic ATF. Special Honda ATF (typically from a dealer) must be used or transmission problems will soon occur.
DeanHensler
01-09-2012 08:06 AM
txedomask433
08-03-2007 06:09 PM
ELLAS1945
07-09-2007 06:44 PM
amsmk
01-22-2006 01:57 AM
