Antifreeze
Antifreeze
Sorry if this is in the wrong spot . What kind of antifreeze do I use? Is it available at NAPA or Carquest since those are the only two available around me. How high do I fill the reservour tank? Should it be full hot or cold? Does the tank have lines or something where it should be full, I didn't see any when I looked.
For Michigan's climate, go to the auto parts store (or even Walmart) and get 50/50 pre-mixed antifreeze. You'll probably need about a gallon.
You'll want to wait for the engine to be cold before you start popping caps on the cooling system. It's under pressure, and when it's hot, it's under more pressure which has the potential to be a 210* geyser if you remove the radiator cap.
Are you just topping off the coolant, or changing it?
Before you do anything look in the owners manual & see what type of antifreeze Honda calls for. There is the regular green, dexcool which is orange, & one other that is yellow, I know of. Mixing these is a BIG NO NO.
If your topping off the clear plastic tank there should be marks but if not fill it about half full hot. Make a mark with a black marker where the level is. That way you know it should be close to that mark hot. As temps change etc it will change some but not a great deal maybe a half inch up or down.
turbo_ricer
02-08-2007 09:00 AM
