Another Synthetic vs. Dino Oil Question for My 06 Civic SI
Old 04-28-2007 | 07:15 PM
Grinche's Avatar
Default Another Synthetic vs. Dino Oil Question for My 06 Civic SI
I bought a 2006 Civic SI and I have always ran Mobil 1 synthetic in my Audi's with good luck. This car I bought with 20K in miles on it and I asked the dealer about changing over from conventional oil and he said Honda does not recommened synthetic oil in this engine. He did not say why and I found his statement to be highly suspect. I may add that this dealer has one of those "free" oil change programs for the life of the car programs.
So what gives, is this true that Honda frowns on synthetic oil for my car? If so, why? If not should I make the change?
Thanks everyone for your input.
Old 04-28-2007 | 07:41 PM
riceburner700's Avatar
Default RE: Another Synthetic vs. Dino Oil Question for My 06 Civic SI
its up to you man. look in the owners manuel it will say if you shouldnt run synthetic oil. if you do just run the same oil you would but just in synthetic
Old 04-29-2007 | 01:13 AM
civicb18c5's Avatar
itwont allow vtec to engauge and there are some other reasons to like its bad on the seals
Old 05-10-2007 | 02:24 PM
gabriel55407's Avatar
No no no its not bad for seals and it doesnt keep vtec from kicking in. If someone has this problem after using synthetic its a coincidance. Ive used synthetic in my civic forever with no problems. Tight as a drum and vtec hits hard. The only diffrence between a base oil and a synthetic oil is that its been through all 5 stages of oil refining called "synthesis". This makes it more durable, heat resistant, and increases its lubricity. If an oil is causing a gasket to leak its because of the detergent additive package, not the oil base.
Old 05-10-2007 | 02:30 PM
Fiirkan's Avatar
ORIGINAL: civicb18c5
i would like to see where you found that information
oilltd
06-10-2008 05:06 PM
Dr. Spaceman
10-08-2007 07:02 PM
Vadagar
05-26-2006 01:51 PM
Auto98EX
10-07-2005 07:49 AM
