Another A/C Problem (kind of urgent?)
Old 08-22-2008 | 05:03 PM
also, if the refrigerant level is too low, the compressor will not turn on
  #22
Old 08-22-2008 | 10:28 PM
taylorisafop's Avatar
So I measured it and it says I have WAYYYY too much freon lol. Is this normal?
  #23
Old 08-22-2008 | 10:33 PM
if the a/c worked before, there's no possible way you could have too much freon for the compressor to work... unless you added freon once the a/c stopped working.
  #24
Old 08-22-2008 | 10:40 PM
What are the refrigerant pressures on the low and high side when the engine is idling and the A/C running?
  #25
Old 08-23-2008 | 09:24 AM
mundy5's Avatar
Originally Posted by taylorisafop
Okay, got that fixed, some loose connections and such. Anyhow, help with the compressor?
I don't want to have to replace it. We've jumped it and it won't activate.
What did you do to fix it and what did you fix?
  #26
Old 08-23-2008 | 01:06 PM
If you're talking about jumping the battery to the compressor wire, and it didn't engage, a few things could do that.
First never do this with the engine running, because without the condenser fan the pressure will almost immediately rise out of control and blow the relief valve or a hose.
Check the resistance from the compressor wire to ground, it should be 3 or 4 ohms. If it is open, check after the thermal switch mounted on top of the compressor. If still open you need a new clutch coil. This can be replaced without buying a whole compressor and also without opening the refrigerant system.
If you have the 3 to 4 ohms, with engine OFF jumper the clutch wire to battery plus. See if the clutch snaps in. If it doesn't, press on the clutch plate and it should snap in. This means that the clutch gap is too wide. Unscrew the shaft nut and take the plate off. Take some of the shim washers off of the shaft. Put the plate back on(*), make sure the gap is not so close that it drags when off. Now the clutch should work again.
(*) Note that the way the splines on the shaft are made, the plate can only fit on the shaft in one rotational position. Do not force it on in the wrong position.
  #27
Old 08-23-2008 | 09:01 PM
My problem was actually just the connection to the A/C control, a wire had slipped out of the harness. The dome problem, I recommend you use the old radio and just leave it plugged in, fixed it right up.
  #28
Old 08-23-2008 | 09:21 PM
I actually don't have a way of measuring it right now, seeing that it's 11:21 P.M. here, but I'll tell you as soon as I know.
  #29
Old 08-23-2008 | 09:22 PM
There's actually a chance my stepbrother may have, he had the car before me.
  #30
Old 08-23-2008 | 09:23 PM
I'll give this a shot and let you know how it goes. thanks.
salinagon
10-13-2011 09:55 AM
FlipHKD720
07-12-2006 01:43 PM
gambino
11-21-2005 03:53 AM
frizzlefry99
06-29-2005 07:08 PM
Viper_Is_Hot
10-20-2004 12:46 PM
