Air Compressor Recommendations?
Old 01-10-2009 | 07:20 PM
Shaklee3's Avatar
Default Air Compressor Recommendations?
I've been researching air compressors for a while now that I can use with an impact wrench. I figure I'll need at least 6CFM@90psi. My budget is under $300, and I'd prefer a portable one that is also oil-less. As much as I've looked, I can't find a good option that meets that criteria, or really any portable one that is good for mechanic use. Does anyone have one they can recommend?
Old 01-10-2009 | 10:18 PM
Not sure of the exact one, but I would definitely buy a Craftsman.
Old 01-11-2009 | 12:04 PM
Oil type is generally preferable to oil-less. As long as you keep up with oil changes it will have longer life.
An impact wrench actually doesn't need a lot of air to do one bolt at a time, but it needs a quick burst of high flow. Look for a compressor with a moderately large tank. It's also important to use a large hose between the compressor and the impact. Forget that 1/4 inch hard plastic curly stuff. If you're changing all 4 tires in a pit stop then you would need a large compressor. The racing teams use bottled air or nitrogen under very high pressure for that.
Old 01-11-2009 | 09:32 PM
TheJGB3's Avatar
I have a Craftsman 33Gal., 150psi max oil-less compressor. I bought it on sale for $319.99 (it was on sale and I also got a 10% Craftsman club discount so it ended up being $289.99) and it also came with a free 1/2" drive impact wrench, 3/8" drive air ratchet, and a .401" shank air hammer ($99 value). I have had it for three years and no problems.
Here is the 'new' model of the one I have (currently they aren't offering the $99 value air tool kit with it though).
http://www.sears.com/shc/s/p_10153_12605_00916762000P
Old 01-12-2009 | 05:52 PM
Shaklee3's Avatar
I don't know why I wrote oil-less. I meant I'd prefer oiled after reading the reviews. JGB the one you pointed out only puts out 4.9CFM@90psi. Most impact wrenches are at least 5, and sometimes 6, right?
Old 01-12-2009 | 05:53 PM
I have the same one (the older model that you have), it's a great compressor.
Old 03-13-2009 | 06:36 PM
Shaklee3's Avatar
I found this one on Amazon that looks good. Does anyone have any opinions on it?
http://www.amazon.com/exec/obidos/AS...etsreviews3-20
The reviews are mixed
Old 03-15-2009 | 12:14 PM
STREETFIGHTER50's Avatar
it only has a 5 gallon tank. for that price i'd just go with the craftsman with the 33 gallon tank. works fine for my house & all my impact tools. for $300 there really isn't much options.
chrissy479
04-10-2011 07:31 PM
coffeykevin
07-30-2010 03:38 PM
PonDaCivic
06-14-2009 05:07 AM
Dragon_F
06-05-2009 02:10 AM
MCCivic
04-04-2007 12:45 PM
Quick Reply: Air Compressor Recommendations?
