Advice / Troubleshooting HELP Please... Thank you!
Old 05-09-2007 | 10:56 AM
akar's Avatar
Default Advice / Troubleshooting HELP Please... Thank you!
Hello Everyone,
Just had a situation where i wanted your advise. Have a 1996 Honda Civic EX and have 2 problems
One... a red SRS light has turned on on the dashboard? What is a likely reason for this and is it costly to fix? or neccesary to fix?
2nd... my speedometer just STOPPED working!!!!!
I started the car and the car was idling and the mph gauge went up to 35mph (although the car was not RPM very fast) and then it just DIED!! So now my speedometer and odometer are NOT working??? (tachometer DOES work).
Is this a cable busted, or simply a fuse, or ????? Is this expensive to fix??? Easy or Hard to fix?
I wouldn't be doing the work myself, as i am unfortunately not too mechanically inclined, but i appreciate your input and advice PRIOR to going to a mechanic, so that i have a heads up on what to expect and just want to make sure that we get a qoute that is reasonable.
Thanks in advance,
Your time is MUCH appreciated,
Adam
Old 05-13-2007 | 05:02 PM
Tim706's Avatar
Default RE: Advice / Troubleshooting HELP Please... Thank you!
The speedometer is completely mechanical, so no fuse. It IS cable driven, however the more likely cause than a broken cable is the gear at the end of the cable that runs off the tranny output shaft is probably worn clean, it is only plastic. Either way I believe this would be a cable replacement.
The SRS light is your AIRBAG light. You have an Airbag issue and they are generally costly to fix.
drillers19
07-19-2010 10:44 PM
Brute
08-27-2009 09:53 PM
Thefbomb13
05-23-2007 10:00 PM
jkdalex
04-05-2007 09:40 AM
Quick Reply: Advice / Troubleshooting HELP Please... Thank you!
