AC Compressor Clutch Coil for$950????
Old 09-01-2006, 11:29 AM
deserthonda's Avatar
Default RE: AC Compressor Clutch Coil for$950????
950 dollars........is way way way toooooo much money
the discharge hose is around 100 or so dollars , labor to replace it 1/2 hr
the only thing you need is a compressor coil .. price around 125-175 dollars
labot to repalce it 2-3 hrs and that should include a/c service cause they have to evacuate and recharge system .. also if replacing the coil, the have to disconnect the lower part of the leaky discharge hose ,to remove the compressor , which means to replace the hose all they have to do is unscrew the top nut ( 30 seconds at most )
so if this is a good shop they should NOT charge you any labor to replace the discharge hose ........I know i don't to my customer in a similar situation ..
so to sum it all up
labor 3 hrs ,, $ 210-250
hose $100-125
coil $150
r134a $ 20
you do the math ...
also make sure that they test the thermo protector on top of the compressor ,, i have seen a lot of those go bad but not too many coils,,
ask them if they tested it ,, cause power goes through the trermo protector before it goes to the coil..
Old 09-03-2006, 09:02 PM
fglaustin's Avatar
100 - 125 for a hose;
screw that.
my brother helped a friend of his with a hose problem-
think it was ac and on a saab, or volvo (something like that) -
bought from bulk hose and got fittings put on at a machine shop -
very little cost
Old 09-03-2006, 09:11 PM
Pete's Avatar
Just buy the parts used off ebay and do it urself. Even if u ended up taking 4 days to do it and rented a car during those days, its still half of what the dealer would have charged you.
Old 09-03-2006, 09:17 PM
fglaustin's Avatar
sometimes a person might feel like it is a gamble to buy used off of ebay.
can a new ac hose be found ??
i would not want to buy a used one.
Old 09-06-2006, 08:10 AM
plc00133777's Avatar
ORIGINAL: Pete
I'm just afraid that I may get stuck and end up paying some one to do it, will need to study the job prior to start to ensure I can do it.
I'm a eBay user, so not afraid to shop there since I know what to look for. I'll take my chances.
Hous
06-11-2011 08:08 PM
sto73
03-27-2008 02:32 PM
ericsmc83
09-27-2007 04:33 PM
spunger
05-01-2007 08:08 PM
AgentofDarkness
06-30-2005 07:02 PM
Quick Reply: AC Compressor Clutch Coil for$950????
