AC compressor Blowing Fuses
Old 08-13-2006 | 03:48 PM
plc00133777's Avatar
Default RE: AC compressor Blowing Fuses
Thanks, but if anyone else knows, please advice.
Old 08-13-2006 | 05:48 PM
fglaustin's Avatar
so, you have disconnected the fan and the fuse still blows, right ?
Old 08-13-2006 | 05:56 PM
deserthonda's Avatar
ORIGINAL: plc00133777
Hey,
Did you find the problem? I have a 1996 EX that is blowing the fuse for the AC fan.
disconnect the wire that goes to the compressor, start the car and put a/c on, compressor will not come on ,, I know , but if fuse does not blow you got an issue with the compressir clutch coil ,, or the thermo switch located on top the compressor
if it still blows fuse than you can eliminate those things..and we have to diagnose further ........ let us know
Old 08-14-2006 | 11:41 AM
No, did not try anything yet. But will do once I getr home.
Thanks and thanks to deserthonda also. Will try that also and post results.
Renoth
08-01-2010 02:12 PM
gin0o0o
03-19-2007 05:54 PM
jomamma1
08-19-2006 06:09 PM
wangster
03-17-2006 10:24 PM
mill$civic
05-24-2005 11:56 AM
