AC compressor Blowing Fuses
I have a 1990 lx Sedan,
The AC compressor is blowing fuses,
I have disconnected the condensor fan, and the fuse blows
I have checked the R134A level, just right,
I have checked the wiring to the compressor, A-OK,
I'm out of ideas,
Sometimes it will run for a few minutes, sometimes only a few seconds before the fuse goes..
I'm contemplating jumpiong the fuse slot with a paper clip and taking my chances..
It's BLAZIN' hot here!
Thanks,
Chris
________
Proving Grounds
I'm out of ideas,
Thanks,
Chris
________
Proving Grounds
RE: AC compressor Blowing Fuses
been there , done that - did not happen to my car though.
there is probably more on the circuit to that fuse than just the AC.
check your fuse diagram to see - the problem (probably) is not the circuit of the AC, but something else that is on that fuse. at least my guess for right now.
So you're thinking that there is something else on that circuit that is causing a problem, not big enough to blow the fuse, but when I kick in the ac it overloads it?
just want to verify your thosht process on this.
Thanks,
Chris
________
Herbalaire review
Thanks,
Chris
________
Herbalaire review
Yes, the "It" is the compressor. air works great until the fuse blows I can put another fuse in While the car is running and the AC is on, and the air continues to work... all this while standing still, not many bumps sitting in the garage.
but I will retrace the wirig when I get home.
________
Smoke kills
________
Smoke kills
it may be the case where Chris (chrisktana) will not come back and see your post.
if you click on his name - i think it is provided whereby you can send a private email to him (just not for sure about it, though - i am kind of computer dumb !)
