ac clutch on off every 1 second
Old 01-09-2010, 08:51 AM
OP, below shows the proper method for adjusting the idle speed of your engine. To do properly, however, you really need to hook up an accurate tach or OBDII scan tool that reads engine rpm.
Old 01-11-2010, 02:16 PM
charliccs's Avatar
thank´s for everyone... well I extract the condenser fan and I opened the motor and the brushes and commutator show wear.
have very low brushes.
I buy today in ebay a oem used fan 35$. I wait to receive it in venezuela and install it and I let know everything and if the problem is solved...
thank`s again...
Old 02-18-2010, 04:26 PM
charliccs's Avatar
hello, I change the condenser fan and everything is ok... the problem is solved... I think the problem was the condenser fan is a little bit slow and the pressure in the system is to high that because the clutch of the compresor on off because the high pressure in the system and It took more energy from the engine...
thank`s to everybody help me...
georgecivic
04-25-2012 08:32 AM
skytanker2003
12-14-2005 11:00 PM
skytanker2003
12-14-2005 11:00 PM
duke
12-21-2004 08:32 PM
Bobby
05-10-2004 08:47 PM
Quick Reply: ac clutch on off every 1 second
