ABS Bypass
Old 05-01-2005 | 01:03 PM
porschefan's Avatar
Default ABS Bypass
Can anybody tell me how to bypass the ABS system in my 1993 Civic Ex?
Old 09-29-2006 | 08:24 PM
Lordnismo's Avatar
Default RE: ABS Bypass
unplug it your brakes will work. after you unplug it get up to speed and apply the brakes you should slide that means you`v bypassed it.
Old 09-30-2006 | 07:37 PM
b8teen's Avatar
i wouldnt reccomend that...
Old 09-30-2006 | 11:03 PM
deserthonda's Avatar
if you reside in a snowy winter state i would fix it,,,,,,it could save your life
if you reside in a dry( no snow ) winter state,, AZ, NV, etc,, just pull the fuses out,, the ABS lite will stay lit on the instrum cluster but abs will not work....it will NOT affect the regular brakes.......
i had a 90 acura leg with a leaky modulator 1000 dollars to repair so i just puled the fuses off drove it for 5 years ..
dstroman
03-14-2012 08:36 PM
bfodle
07-20-2011 09:57 AM
martyb555
03-12-2009 07:32 PM
Chirp3rd
05-12-2008 03:24 PM
kukanator1
08-23-2007 05:05 PM
Quick Reply: ABS Bypass
