ABS or braking problem.
Hi All
Recently I've noticed when I apply the brakes lightly, the pressure is inconsistant.
The best way I can explain it is when you have a bucked tyre on a push bike and you apply the brakes as the wheel goes round, it sticks where the buckle is, but is loose and not making contact on the rest of the wheel.
I would get the same effect if I tapped the brakes, causing a juttery slow down.
It's getting progressivly worse I believe, but I only feel the effects when the brakes are lightly applied, when I put the pedal down harder, it still comes to stop.
Could be anything from pads, to rotors, to a faulty ABS system (had trouble with it in the past).
Any suggestions on how to diagnose the problem?
Cheers
Cheers
dstroman
03-14-2012 08:36 PM
bfodle
07-20-2011 09:57 AM
martyb555
03-12-2009 07:32 PM
Chirp3rd
05-12-2008 03:24 PM
kukanator1
08-23-2007 05:05 PM
