99 Civic EX with D16Y8 swap (from a 98)
i have a 99 ex 5 speed. starting the car and driving it cold to warm, or even when it just starts getting warm and drive, the car accelerates perfectly normal. after driving for 15-20 minutes the car mildly hesitates during acceleration between 1500 & id say about 3500rpm mostly in 2nd, 3rd & 4th. its not bad, but a light hesitation. any ideas what it could be? no CELs, the plug wires, plugs, dizzy cap and rotor are all new
duralast gold cap n rotor, duralast plug wires, tried ngk platinum plugs and tried a set of ngk copper plugs, gapped them to .52 and tried plugs gapped to .44. The CEL does work because when i pulled the primary o2 sensor plug out the light came on. i reset it and still have no CEL
its not a violent hesitation or rough jerking, it will jus hesitate and lack power. usually when the car has sat for a while or overnight and is then driven it accelerates perfectly normal for the first 10 minutes or so. then once its warm, or if i come off of a highway into an urban setting and ill be rolling in 2nd or 3rd and if i go to accelerate it will hesitate and jerk all while still somewhat accelerating and once the rpms get to about 3500 - 4k its usually fine.
