98 Civic EX- Windows Won't Work (electrical)
I'm new to the forum but i figured you guys would know how to help. I have a 98 Civic EX (4 Door) and well, the windows won't work (exception: the driver's side window still works fine, along with the moon roof). this wouldn't be a problem except that the passenger window is now stuck down... I got the front windows down, but only the driver's side will roll back up. I thought it might have been just the wiring in the driver's side, so I tried using the individual switches to no luck. Any suggestions? I've checked the fuses (both interior fuses and the ones in the engine compartment...)
Thanks for your help
-Tim
-Tim
RE: 98 Civic EX- Windows Won't Work (electrical)
Check all the connections. My pass side one came loose and it made them not work. Also there should be a little box inside the drivers side front door that has the control relays for the windows. That might be whats wrong.
Also, welcome to the forum.
4trw,
This doesnt really help your case but maybe you could help me - which fuses work the pass side window (do you remember the numbers?) thanks, sorry to kinda hijack the thread, I've been having a similar problem but with the window stuck up on the pass side.
Also could be problems with either the regulator or the motor - I think there is a good DIY on here, but I guess I'd make sure that is what it is before you start tearing your door apart...
Rwb003
08-11-2013 06:51 AM
couly
09-05-2010 01:33 PM
Pyr0TeK
03-29-2007 02:34 PM
