97 EK Type R.... WATER IN CABIN.... HELP!!!!!
Hey there,
my 97 EK (right hand drive) has just started taking on water on the left hand (passanger side) and i have no idea where it is comming from, i am currently pulling the seats and everything out to remove the carpet and there is just water everywhere.
someone please help me before my car floods completely
let it dry out then use a water hose and wet the car down and look inside to track the leak. it can be froma door jam seal, the windshield, or an inner fender liner is gone and the water from the tires gets slug into the door jam. do you have a sunroof? check it for leaks.
It could also be water that the A/C system has condensed out of the air. The water is supposed to drain out to under the car through a hose. If the drain is blocked it will spill from under the dash into the passenger side floor area.
redliner25
11-01-2007 03:17 AM
Auto98EX
08-15-2005 02:04 AM
