97 Civic DX Cooling System problem!!!
Whats Up ??
the thing is, a couple of weeks ago, my radiator fan stopped working, i tested the fan and it worked,then i changed the fan switch and the fan relay, after that it was working normaly, but not so long, it stopped again, but this time i changed the fan switch and the thermostat but at this time it did not work, what shall i do now?
I understand everything has been changed out recently, but have you jumped the fan switch recently? You stick a paperclip into the harness side of the fan switch, then turn the key to ON. The fan should come on. If not, there is a fan motor problem, or a wiring problem. If the fan does come on, it is a fan switch, or relay problem.
Make sure the cooling system is completely full. If there is no flow through the radiator, the fan switch will not get hot enough to turn the fan on, even though the engine may be overheated.
Check the fuse box where the fuse and the relay plug in. If the plastic is melted, replace the whole fuse box.
Rustyadams
07-27-2013 05:25 PM
Seth
03-20-2012 03:27 PM
snowie
03-24-2008 10:01 PM
