96 Civic Power Acc Issues
Ok, this is my son's car so I don't worry to much about it but this is a wiring issue that seems to be getting worse.
Started out that the passenger window stopped working. I can power it up at the wires and raise it and lower it so it is not the motor. At around the same time, the drivers power mirror stopped. About 3 months ago the power door locks stopped working...when you hit the power lock it will lock the driver's door but not the other doors. About a month ago, the driver's window stopped working....again, I was able to power it with a jumper to get it raised. I checked the fuses and the switches (replaced the driver's switch with a donor switch).
I am guessing there is a short somewhere, but I have no idea where to start chasing that.
Any ideas?
Any ideas?
I don't know if Honda's have a specific problem but if the car is older or higher milage I would suspect that the short could be in the bundle of wires between the driver's door and the body of the car. Also double check the connections between the harness and the controls in the driver's door. Not sure what else to tell you. Best of luck (I hate tracking down wiring issues....)
addiction2bass
02-13-2008 07:59 PM
tigger
01-14-2008 12:46 AM
Auto98EX
12
09-30-2005 03:33 PM
