96 Civic AC doesn't work when hot
The AC on my girlfriends 96 Civic works fine...until the outside temperature rises above about 85 to 88 degrees. At, or above, that temperature the AC will only blow hot air. Below about 85 degrees, the AC is fine and blows cold as can be. Refrigerant levels are fine, and there are no vacuume leaks. I was thinking a relay or part of the wiring might be overheating...If any one has had this problem or has any ideas, help would be greatly appreciated. Thanks in advance, Chris
RE: 96 Civic AC doesn't work when hot
You might want to look at the "ac radiatior." If the fins are bent, or there is obstruction on it, like paper(very common) it will not cool as efficient as it can especially when outside temps are higher.
jpj
11-23-2011 01:45 AM
andrew porter
11-20-2008 04:38 AM
ajluu
05-08-2008 10:58 AM
kidintheshadows
12-14-2007 02:12 PM
1996, 96, ac, air, blows, civic, conditioning, days, doesnt, honda, hot, leak, temperature, temperatures, work
