95' EX very sluggish acceleration-Bogging down
I had a very crazy up and down idle for a couple weeks and figured out that it was because of my aftermarket throttle body gasket was not a direct OEM fit and was blocking a air hole. I fixed that but now I have a very slugish acceleration, it bogs down and has severe loss of power. I never had this problem til the idle problem happened. Anyone have suggestions?? does it just need to run a while to go back to normal?
If the engine is now idling to spec, then an air leak is highly unlikely. In addition, an air leak won't cause engine bogging. Inspect the plugs, cap, and rotor, and also check the ignition timing.
did you check the plugs on the intake mani because they can get swapped i had that same problem when i swapped enginges. it idled fine and when i gave it gas it just bogged down really bad and wouldn't rev up.
