95 civic overheating please help!
Old 09-03-2010 | 10:36 AM
Sage's Avatar
Default 95 civic overheating please help!
ok so i have a 95 honda civic ex thats overheating. At first the temp went all the way to the red zone and after changing a couple of sensors and getting a new thermostat it still overheats to about 3/4 of the way before the meter gauge didnt even move :/. also when i drive it all the antifreeze is pushed back to the reserve tank and starts boiling making it spill out none comes out the radiator itself just the reserve/overflow tank. can somebody please tell me whats up please?
Old 09-03-2010 | 12:24 PM
Excessive coolant entering the overflow is either the radiator cap is failing, or you blew the Head gasket.
Since you overheated the car up to the "Red zone", you popped the Head gasket causing excessive air to enter the system. Another thing you can check is the oil to see any coolant is mixed in there. Same when draining the coolant (check if oil is mixed in). It will look like a milky, chocolate brown color.
A compression and/or leak down test can confirm a blown HG, too.
Old 09-03-2010 | 01:52 PM
Sage's Avatar
damn if its a blown head gasket its gonna suck for me, someone else told me it might be happening because i didnt purge the system right when i changed the thermostat and air entered the system. but thank you very much for your answer i will check that this weekend.
Hell Monkey
09-20-2012 04:43 AM
keigaro
05-21-2012 09:53 AM
bkloos
05-15-2012 09:16 AM
xpdude
11-06-2009 09:03 PM
trebor_2005
05-19-2006 01:40 AM
Quick Reply: 95 civic overheating please help!
