95 civic air conditioning
Old 09-16-2008 | 06:05 AM
etpeek's Avatar
Default 95 civic air conditioning
Does anyone know how hard it is to change the evaporator. I've got what I believe is an ac leak. I put the leak detector in the system and the dye is coming out the condensation drain underneath. I think that is coming off the evaporator. If anyone has any expertise I'd appreciate your knowledge.
Thanks.
et
Old 09-16-2008 | 06:14 AM
It's very simple. Recover the refrigerant. Remove the battery. Disconnect the refrigerant lines at the firewall behind the battery and plug them to keep moisture and dirt out. Remove the glove compartment (unscrew the hinges at the bottom). Remove the reinforcer plate behind the glove compartment. Take off the wires, straps and bolts and drain tube and remove the evaporator box from the car. Take the clips off the box and open it top to bottom. Replace evaporator or other leaky part you find in there.
Old 09-16-2008 | 01:41 PM
mundy5's Avatar
Originally Posted by mk378
It's very simple. . . . Remove the reinforcer plate behind the glove compartment. Take off the wires, straps and bolts and drain tube and remove the evaporator box from the car. Take the clips off the box and open it top to bottom. Replace evaporator or other leaky part you find in there.
sounds so easy in writing but for a novice like me, that sounds awfully intimidating to say the least. i'm sure one day I'll have to do something like this as well.
Old 09-16-2008 | 02:09 PM
On most American cars it is necessary to take the whole dash apart to replace a leaky evaporator. It can be an all day job. A 1990's Civic is very simple by comparison.
Old 09-16-2008 | 02:17 PM
yea on civic's it's easy because the cars are designed for a/c to be installed quickly by the dealer, since it was optional on lower end models of the civic
Brian
07-05-2012 12:05 PM
jesskendrick
05-15-2010 11:09 AM
bloomonkey89
04-11-2008 08:00 AM
maximummax001
08-02-2006 11:25 AM
fletch71
07-20-2005 08:25 PM
