'95 civic 1.6 4cyl auto-trans
All i know is that when you push the break pedal, it "unlocks" your automatic shifter.
Look for a switch around your break pedal. maybe its loose or it went bad or something.
BTW does your horn work?
Check your fuses
Check your fuses
Last edited by DaOne; 01-26-2011 at 06:56 PM. Reason: Went out to look for it myself lol
It should be able to start in park OR neutral. If not check the interlock switch on the shift lever.
The system that locks the handle in park unless you press the brake is on the the same circuit as the brake lights. Check if the brake lights work first.
georgevega
09-19-2011 04:32 PM
The_Bobkat
08-19-2008 05:00 PM
cfauvel
09-22-2005 01:23 PM
