94 honda civic vtec engine removal
Yes.
You need to remove the whole thing, engine and transmission. The axles are attached to the transmission. You don't wanna try to float the transmission while you pull the engine. It's much simpler to pull the whole thing at once.
It may seem that way, but it isn't.
I recommend going to www.hondatech.info and downloading the service manual for your generation (95-95). It will give you detailed instructions.
he gave you the link to download the service manual... did you read the instructions? How hard does it look when you read the manual?
Also, we have a DIY section with a DIY on removing the axles.
https://www.hondacivicforum.com/foru...ad.php?t=42185
Lift the front of the car off the ground and support it. Remove the wheels/tires and undo both lower ball joints. Pop the axles loose and then pull the axles out of the transmission by swinging the hubs out. It is not necessary to remove the axles completely from the car.
Mikester
06-17-2014 05:47 AM
rayo
12-05-2012 01:09 PM
abra0101
07-23-2006 08:47 PM
