94 honda civic
faulty coil wire maybe? or something wrong with your fuel pump maybe? week ignition relay maybe? whens the last time the distributor cap and roter where changed? im not a mechanic or claim to be one just throwing out some ideas and maybe some senior members could jump in and help ya..
More detailed information about the problem is needed.
Are you saying the engine only runs when the key is held in ON(III)/START?
If you tun the key to ON(II), do you hear the low humming sound of the fuel pump priming for 2 seconds in the gas tank? And does the CEL turn on and then off after 2 seconds?
sorry one thing i forgot is when turn key on dash lights dont come will stay running only if you keep key turned all the way changed ignition switch didnt fix also put new map sensor is 5speed dont know what cel is
