94 hatch with speedo problems
Hey just got a 94 VX hatchback and the speedo isn't working. I have read a lot of bad speedo threads but mine is acting a little different. So when the key is in the off position the needle is on 0 turn the ignition to on and the needle jumps up to 25 mph. When I start the car it goes to either 15 or 25 mph. Then when I start moving right around 2-4 mph the needle is bouncing from 0 all the way to 60, once I get going about 10 it stays steady on 25. ??? I am lost on what could be wrong looked at the VSS plug looks good. Any ideas??? Also tach and all other gauges work fine only the speedo and odometer aren't working.
KLK99CIVIC
09-05-2010 05:14 PM
wjelmer
10-16-2006 06:07 PM
