94 civic vx
94 civic vx
Hi all,
I've read through some posts here and have found problems similar to mine. My car will start and run for 10 to 15 mins then stall. If I let it sit for 10 mins it will fire right up. The car tends to bog down if I have 3/4 tank of gas or better. I've replaced the starter, distributer, main relay, fuel filter, bypassed the starter relay, axles, all in the past 3 months and dont want to dump much more money into it. any ideas?
When the engine won't start, listen for whether the fuel pump primes for a few seconds when the key is turned to ON (II) without cranking the engine. Also check for spark at all four plugs.
Is the CEL ON?
Is the CEL ON?
Yes, but check for voltage between the YEL/GRN and BLK wire at the fuel pump. Do the test only when the engine won't start. Keep in mind that interpretation of the test results may be tricky due to the fact that the problem is intermittent -- so repeat test multiple times.
ok, found a couple problems, first the cel light is out so I got a new one but haven't had the chance to replace it yet. I was finally able to recreate the problem. When the car stalls out, I get no spark so I'm thinking distributor which sucks because its fairly new, and I'm sure I dont have my receipt...
Ron thanks again for the info,
Autozone swapped out my distributor under warranty, got the car fired up and ran good. I also swapped out the cel light, and as soon as I got on it the light came on. Came home, jumped codes, and came up with 48, o2 sensor. Got that comming from a friend so we'll see what happens...
