94' Civic EX Won't Start
Old 07-14-2011, 12:16 PM
sspatriots's Avatar
I didn't see anything else in the box except for what was in the picture. I bought it off of e-bay because it said it fit all honda civics from 92 to 95. Here's the link to it:
92 93 94 95 Honda Civic Ignition Switch Wiring NEW | eBay
  #32
Old 07-14-2011, 01:32 PM
sspatriots's Avatar
Half way there, that is, I did manage to get the 2 small blue/wht wires out. I ended up using a dremel tool to cut away the shell of the old connector and the wires came out rather easy. Now I'm trying to figure out an easy way to put them back in because they seem to have to go in there pretty far and still don't have a tool that will push them down in there. I'm open to any ideas.
Thanks,
Steve
  #33
Old 07-14-2011, 04:44 PM
sspatriots's Avatar
Just wanted to jump back on here to thank everyone for all the professional help. Great forum and I'm sure you'll be hearing from me again.
I got the ignition switch on finally and all seems to be going well with the new ignition switch. As for how I got the stubborn spade terminals down inside the new ignition switch, I ended up taking an old screwdriver and flattening out to a single thickness for the bottom 1-1/2" or so and grinding the sides to a single width. Then took the same dremel tool I used to cut the connector open to get the spade terminals free from the old connector to cut a small notch in the end of that screwdriver. After that everything seemed to be smooth sailing...
Regards,
Steve
David_S
10-24-2013 10:06 AM
mikeym
05-31-2006 09:09 AM
ShaneC
08-07-2005 05:12 PM
Blacklion
07-12-2005 01:01 PM
randocsmith
07-08-2005 05:53 PM
Quick Reply: 94' Civic EX Won't Start
