92 civic hatch strangely not starting
just bought the car with mini swap. that went about 15 miles before blowing a hole through the side and blasting apart the crank. checked for p28 ecu and bought d16z6 engine for replacement but now that wont start. reset timing, checked injectors and spark. all checked out fine. car just turns over. doesnt fire at all. anyone with any ideas?
finally got to working on the car again. timing is on 100 percent. but if my eager friend turned it over beforehand could ihave bent the valves? doing compression test later. any other way to look at them? the head from the old motor is still good. but i don't want to swap them unless i have to.
