92 Civic DX Hatch needs ignition assembly
Old 01-05-2012, 11:41 AM
partyshark's Avatar
Default 92 Civic DX Hatch needs ignition assembly
Long story short, my car was stolen, stuff was taken, and my ignition was screwed. Everything is fixed except for my ignition. It had to be drilled so i could drive it home. Apparently the whole assembly needs to be replaced. For I know very little about cars I have decided to come here and ask for assistance.
So, my questions: Can I replace the assembly easily? Is there a guide online I can follow? Can I get the proper parts cheap and easily?
Hopefully I have posted in the correct section.
EDIT: So apparently its more than just the assembly. I am sorry, I don't know what it is called. Thats why I am here :/
Old 01-05-2012, 12:50 PM
There are three major parts. The white plastic part with big wires is the ignition switch, it engages the shaft in the metal part which rotates when you turn the key. The metal part holds the cylinder, also has a mechanism to lock the steering wheel and also since your car is automatic there is a mechanism where you can't turn it all the way to lock without shifting to Park first. Finally the cylinder is the actual slot where the key goes in, it detects if the correct key is inserted and won't rotate if the key doesn't match.
Old 01-05-2012, 12:54 PM
partyshark's Avatar
Thanks! So if the mechanism holding the cylinder lock is drilled would the the lock and the thing that holds it be the only things I need to replace? If so, how simple/hard is it?
Old 01-06-2012, 03:24 AM
partyshark's Avatar
Problem was fixed. You may remove this. Thanks.
jdm89
01-28-2008 02:46 PM
b_rice burner
22
11-25-2007 02:34 PM
solewheelin
07-30-2007 03:03 PM
mk12booze
10-24-2006 03:39 PM
nyorkrider
03-18-2006 06:17 PM
Quick Reply: 92 Civic DX Hatch needs ignition assembly
