91 si with D15bVtec NO START HELP! plz
Old 08-21-2009 | 08:39 PM
First make sure the mechanical timing is perfect. If so, you'll need the right distributor.
The OBD0 fan switch is located at the rear of the block. For your swap, the fan switch on the thermostat housing will ground (Yel/Grn wire) the radiator fan motor, which gets power (Blk/Yel wire) through fuse 15:
(OBD0 diagram)
  #22
Old 08-21-2009 | 09:56 PM
yes a vtec dizzy's bolt holes doesnt line up with the head's bolt holes. and vice versa.
yes hook the fans up like mentioned ^
for it wanting to die when you give it gas, check the wire harness there are 2 plugs that have the same type of plug and gets easily crossed. the tps senor and the map sensor
  #23
Old 08-22-2009 | 07:54 AM
ef9101's Avatar
so the thermostat housing sensor i just ground the female black ground to the obd0 fan motor
  #24
Old 08-22-2009 | 07:56 AM
ef9101's Avatar
ill flip the tps n maps right now hopefully we get a difference
  #25
Old 08-22-2009 | 07:59 AM
ef9101's Avatar
just wanna run somthing by u guys real fast for the fan motor the female plug out on the harness has blk/ylw n blu/gry i dout it makes a difference but do i run the ground from thermo sensor to the blu/gry since theres no ylw/grn
  #26
Old 08-22-2009 | 09:14 AM
ef9101's Avatar
think i get it now i adapt green from the thermo plug to blk/ylw n adapt blu/gry to black wire on thermo plug ...correct me if im wrong please
didder
07-10-2008 10:44 PM
Pukie95
01-21-2008 08:59 AM
donndiego
04-01-2007 07:24 PM
that_guy5
02-09-2007 08:09 AM
antojl
05-29-2006 11:47 AM
Quick Reply: 91 si with D15bVtec NO START HELP! plz
