91 si with D15bVtec NO START HELP! plz
Old 08-21-2009 | 06:45 PM
ef9101's Avatar
well i checkd all the fuses n ground all is good to go..but everytime i give it a 5 min rest n try to start it up it stays on jus a lil longer u think because the motors been sittn so long its just resisting life
Old 08-21-2009 | 06:47 PM
Check the mechanical timing of the cam and crank.
Pull the plug and check for fuel and flooding in the cylinders.
Old 08-21-2009 | 06:49 PM
What color is spark?
Old 08-21-2009 | 06:50 PM
ef9101's Avatar
well i just tryd to start it one more time it stood on for bout 20 seconds its a record so far so i think all it has to do it brak into place but ill check the timing
Old 08-21-2009 | 07:08 PM
ef9101's Avatar
dnt hav the timing light but moved distributor around fired up idle at 2000rpm till i tryd to move the distributor less moved it to much n of course died out but looks lik its gunna be timing thanks ron ill keep u up dated on its performance i still gotta hook up the vtec oil pressure sensor only ecu code i seem to be getting now
Old 08-21-2009 | 07:15 PM
Yep, sounds like the timing belt may be off by one tooth.
Old 08-21-2009 | 07:26 PM
ef9101's Avatar
never changed the timing belt its a original timing belt stampd honda on it reason we didnt change its in good shape lol so i dout it could be off a tooth but maybe a possibility i got a question about the distributor tho it will not mount up or line up to the distributor holes on the head y is that is obd1 z6 distributor different from d15b
Old 08-21-2009 | 07:29 PM
Yes, I believe they're different.
Old 08-21-2009 | 08:15 PM
ef9101's Avatar
yea i figure there different code for d15b dist. is td42 n i got a td41 so but for most part its idleing okay but giv it gass wants to die? do u no why and also i have a question about the fan on obd0 motors there is no fan switch on the thermostat housing but on obd1 there is i dnt got it hookd up so the fan will not go on had to shut off motor due to heat but do no how id run it
Old 08-21-2009 | 08:16 PM
ef9101's Avatar
would i run the ground wire to earth ground n the power wire to the old obd0 fan power wire? thats what id figure i should do but idk
Quick Reply: 91 si with D15bVtec NO START HELP! plz
