91 Honda Civic HELP starter won't crank
Old 10-22-2010 | 11:12 AM
etteyvees's Avatar
Default 91 Honda Civic HELP starter won't crank
Car was working fine then one day when I tried to start it I heard clicks and the starter wouldn't crank. Having what I thought was this problem before...I replaced the relay. That didn't work. It still clicks and no crank. I can bumpstart the car since it's manual but that only works good when I'm on a hill. Please can anyone help or any ideas would be quite helpful. Thanks
Old 10-22-2010 | 01:00 PM
Have the starter tested. It's probably bad.
Old 10-22-2010 | 05:16 PM
Turn the headlights on and watch when you try to start the car with the key. In the daytime you can used the dome light. If the lights dim severely or go out, check the connections at the battery. The battery could also be run down or defective.
If the lights stay on and the click you hear is [i]from the starter[i], the starter is almost certainly bad. Also check the ground wires on the engine and transmission. You can measure voltage between the big terminal on the starter and starter ground while trying to start, if it stays up but click and no start, definitely bad starter.
lovestodrive
08-20-2021 11:44 AM
TRWeiss1
17
03-06-2020 05:47 PM
zerojett
10-18-2011 03:01 PM
bridgitt
08-06-2011 10:01 AM
comapro
14
10-20-2008 02:05 PM
Quick Reply: 91 Honda Civic HELP starter won't crank
