90 civic stopped running
Old 05-26-2008 | 07:59 AM
dclayton18's Avatar
Default 90 civic stopped running
I have a 90 civic 1.5 hb and it stopped running. I have checked the brain box and it flashes 16 times, i have replaced the fuse / main relay and still nothing. I don't hear the fuel pump kick on when i turn on the key? NEED HELP PLEASE I have taken the fuel pump out and hooked it to the battery and it works but i have no power at the harness where it plugs in at.
Old 05-26-2008 | 09:12 AM
Default RE: 90 civic stopped running
Is the main relay getting battery voltage? If so, the problem is the main relay or fuel pump connector or the wires in between.
Old 05-26-2008 | 10:08 AM
dclayton18's Avatar
Is the main relay by the fuse box if that is it yes it is clicking when i try to start it
Old 05-26-2008 | 10:34 AM
Main relay is to the left of the fuse box above the left kick panel.
Did you already replace the main relay? If so, do these electrical tests:
Old 05-26-2008 | 10:45 AM
jpnolan's Avatar
is the starter turning?
Old 05-26-2008 | 11:40 AM
dclayton18's Avatar
main relay is new and motor will turn over but will not start. I put gas in the carb and it will run
Old 05-26-2008 | 11:51 AM
Doing the electrical tests in the posted picture above should identify the problem.
Brian
16
12-25-2021 03:12 PM
TCory1
10-26-2011 12:32 PM
jcronin885
10-20-2010 03:03 PM
hans747
07-15-2006 11:05 PM
idprints
03-30-2005 05:42 PM
Quick Reply: 90 civic stopped running
