90 Civic si hatch starting problems
okay so tonight i threw in my ignition switch. the car started right up. but it usually only does it 1 or 2 times a day. so i will keep it posted. and my idle is at like 1300 what is my EF's idle supposed to be around?
ef idle for first start could go from 2000rpms n should lower down to 1 1/2 rpms in bout 20 secs or less n then when the cars good to go idle should be at 1000 rpms or a lil higher
so did u check the codes what code did it give you
totenkopf
05-31-2007 04:36 PM
civichonda1994tampa
02-03-2007 02:47 PM
Vendo
06-04-2006 12:56 AM
