89 Honda Civic VSS
94 is right, before 1992 the speedometer and odometer are purely mechanical. The VSS is an electrical switch built into the speedometer in the cluster. Clearly if the speedometer isn't moving, there will be no signal from the VSS.
Easiest way to check the cable is to disconnect it at the transmission (remove spring clip on the side, pull cable out) then pull the cable out of the housing. If it doesn't all come out including the square part on the end that drives the speedometer, you need a new one. You should be able to disconnect the speedometer end by taking the trim off of the dash above the cluster (look through the windshield to see where the screws are).
xalents23
04-24-2008 09:28 AM
