89 honda civic hatchback si
Old 01-01-2010 | 09:25 PM
crackraider's Avatar
Default 89 honda civic hatchback si
for some reason it stopped shifting into reverse
Old 01-03-2010 | 01:32 AM
brock1912's Avatar
that would be a manual tranny, right?
Old 01-03-2010 | 02:26 AM
JayVee's Avatar
a new tranny would solve your problem
Old 01-03-2010 | 04:49 AM
WayToFast's Avatar
More info would help. Does it make any sounds. What have you tried? Have you checked the reverse lock out.
Old 01-03-2010 | 11:23 PM
it is a five speed it does not make any sounds
just like the gear disappeared all of the other gears are fine i have not taken the shifter apart or anything
Old 01-03-2010 | 11:27 PM
JayVee's Avatar
hmm, correct me if im wrong but could the gear possible slip?
Old 01-04-2010 | 04:26 AM
When you move the handle to reverse, do the back-up lights on the back of the car come on? That would prove that the linkage is OK and the problem must be inside the transmission.
Old 01-05-2010 | 01:55 PM
no the lights do not come on no noises anything
Old 01-05-2010 | 01:58 PM
Is the backup light bulb burned out? Is there battery voltage at the receptacle?
Old 01-05-2010 | 05:57 PM
Get under the car, use pliers to grab the U-joint where the shift rod goes into the transmission, twist the linkage clockwise and push forward (into the transmission). I think that should be reverse. Check the bushings on the rod under the shift handle.
jo7man4
01-18-2007 04:16 PM
Akiramashima
07-27-2005 05:48 AM
ibrendlefly
02-22-2005 06:19 AM
ibrendlefly
12-05-2004 01:44 PM
David
08-03-2004 05:35 PM
Quick Reply: 89 honda civic hatchback si
